Keep your existing Hackaday.io projects up-to-date with your mobile device and this companion app. Capture photos of your hardware projects, caption them, and log your project progress.
How it works
- Take a project photo, crop and rotate if needed.
- Write a caption for your log.
- Select an existing project including private projects.
- Title and create a new log.
- Or choose an existing log to append to.
- Review and post your project update.
Get started
Keeping regular logs of your ongoing hardware projects is the best way to take advantage of the community support and broad visibility provided by the Hackaday.io platform.
Use this app alongside your existing Hackaday.io account. Don’t have an account? Sign up at Hackaday.io.
The app is available for iOS and Android:
Logging in
Your existing Hackaday.io email and password are required to login. If you signed up with Twitter or Github these options are available at the bottom of the login screen.
If you have forgotten your password you can create a new password here.
Photos and editing
On the photo capture screen you can take a new photo or access the photo gallery in the top right. Rotating and crop tools appear after a photo has been captured.
Posting to a project log
Choose from an existing public or private project. Then select from an existing log or create and title a new log. New projects can be created here.
Logging out
From the home screen, click on your avatar in the top right to open the user menu. The menu contains a logout link as well as other options.
Feedback
For general app feedback or questions you can comment below or on the Hackaday.io feedback page.
AG MasterZ provides the best apps & game. If you are interesting visit our website.
The Gulf Expats Guide is designed to help both new and established expats get the most out of living in the Arabian Gulf countries. Here, all issues are addressed related to iqama, penalties, Absher, fines, and other technical matters.
save money on web hosting all you have to do is just apply
https://www.webhostingscoupon.com/hostgator-coupon-code.html
Capture and log mobile app is now invented. App and it's working is here which tell ever about the invented things which showing whole for buy term papers. So when you seriously make it then with a compete information we can do it for us.
donations please paypal.me/pools/c/8jILMOGBei
I am trying to get serialplot working on a linux pc but have run in to problems. I downloaded the AppImage chmod to executable, and tried to run on Fedora 30. Failed. Couldn't find Qt platform plugin xcb. Adding "export QT_DEBUG_PLUGINS=1" and trying again yielded more info: can't load libqxcb.so: (/lib64/libfontconfig.so.1: undefined symbol: FT_Done_MM_Var)". Tried again on Fedora 27, but failed with "QGtkStyle couldn't resolve GTK." After failing to get serialplot running on Fedora 30 or 27, I am at a loss as to how I should proceed.
You don't need ps2 to uart converter to attach a keyboard, you can directly connect a keyboard micro it requires a timer and an interrupt enabled pin. If you want can help.
Great idea, I'm going to give it a go.
One suggestion: clicking your picture/profile info should open my hackaday profile in browser.
hello
I tried it out and I like it. It's bare bones but it's easy enough to use that I can easily sneak it in my workflow.
Good job with this!
btw the manula has been taken from Antlabs. https://docs.wixstatic.com/ugd/f5a1c8_d40d077cf5c24918bd25b6524f649f11.pdf
For political correctness, please, if you take other poeples files, tell where you have taken them from.
Hi all,
Designing Sci-FI: Interfaces sci-fi / Futuristic Idea Rotary InFlow, Mechanically simple, Total Efficient Systems.
Conceptual Engineering Application, Detail Idea Tip/Technology Submission - State of the Art - Novel InFlow Tech - Featured Project Development; 1-Rotary-Turbo/Gearturbine, 2-One Compression Step/Imploturbocompressor:
Im Individual Inventor, and this is my Work. And I want to show, Here in this Great Site, Great Artist and Designers Platform, as a Conceptual Detail Idea Tip, To Present as New Technology Innovation, and see this Post info, in a way as a view of Designers Platform as a Conceptual idea, for a vehicle Performance System (Work use Application), as a power-plant and propulsion system, in a Novel way, (“Designing Futuristic Sci-FI if you want”). New Kind a Power-Plant, and a new kind a Propulsion to.
(Note; I make this post, as Idea of another different (new one) option, as a power-plant system novel kind. And here Because this concepts, can work to, and different kinds a flows, but I know still a project, And I just want a present in this platform, to show at people were know about atypical engines types, and power-plant and propulsion systems and rotating machinery).
Featured Project Development - State of the Art Novel InFlowTech: ·1-Gearturbine RotaryTurbo, ·2-Imploturbocompressor One CompressionStep: |/ *1; Gearturbine Project, Rotary Turbo, Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD · With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses · 8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type. |/ *2; Imploturbocompressor; Imploducted, One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Imploducted Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is possible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature. http://stateoftheartnovelinflowtech.blogspot.mx/
Good Day Everyone!
Would you like to visit our webpage: http://www.731roof.com
We are Cincinnati roofing contractors proudly serving our area since 2007. Our expertise and quality work have given us Master Elite and Select Shingle Master status with the highest quality roofing suppliers. As Cincinnati roofers, we understand that your home is more than just four walls and a roof, which is why we are also a premier siding contractor and window contractor. So the next time you are in need of roofing, siding, or windows, give us a call. Schedule your free estimate today!
Services:
-Roofing
-Siding
-Windows
-Gutters
-Commercial
It will surely be better than the Instructables app. Lol. (No sarcasm intended. The Instructables app is terrible.)
It only pulls projects from 2014 till 2017 for me :D the last one is the 433MHz MQTT thing, I presume it's capped somehow?
And after creating and posting a new log, the app crashed. Also the fire emoji was converted to a question mark.
Rocking a Samsung S6 edge, Android 7.0 - cool stuff though!
man this place got spammed o.O this is still a current problem for me
nice idea! It would be nice to be able to add logs without pictures though
Same here. I would also like to be able to start a log with text, and then take a picture after I've started.
@Grant Giesbrecht + 1
+ I would love in this version to be able also create project and start to insert photos in it
I would like have a account on mastodon on hackaday, cell phone ap? no not for me
Nope, not yet.
