I couldn't find the footprint for the ESP32S Devkit anywhere, so I made my own.
You'll find it in the files section.
A project log for Muffsy Stereo Relay Input Selector
Open Source, versatile audio relay input selector controlled by an ESP32
Thank you very much! It helped me a lot!
Hi, Sorry ignore my last post. Everthing ok, my fault, I found it. Thanks for the lib, it saves me a lot of work.
Hi, please could you check the download files. There is an entry for the ESP32 Eagle Library , but the download content is something about a relais curcuit, not the Eagle lib.
help me please... i don't know where i can download lib
https://hackaday.io/project/46280/files
i dont see download button. pls check
Thank you, this will help me a lot!
donde lo descargo?
I used your library. But after board manufacturing in China, I realized the distance between both pin rows is 100 mil ( = 2.54 mm, or 1/10 inch) too small. How does this come? I use the Devkit V4. Have earlier versions been smaller?
