macduff/ fixed the fence to a sliding support platform
Will continually add still pictures of all the updates and ideas for table saw safety
DSC09385.JPGwill cross-cut 8ft sheet material with the use of the outrigger which has but one line of friction along the top of the round pipeJPEG Image - 3.74 MB - 02/04/2018 at 21:48 |
DSC02776.JPGsimple if you think about itJPEG Image - 3.53 MB - 02/04/2018 at 21:47 |
DSC02398.JPGThe jimmy jigs lift off guard, central pivot is automaticJPEG Image - 2.75 MB - 02/04/2018 at 21:44 |
DSC01224.JPGvery simple cross-cut -sled on the Jimmy JigJPEG Image - 3.33 MB - 02/04/2018 at 21:43 |
_DSC8587.JPGJimmy jig in SpanishJPEG Image - 3.15 MB - 02/04/2018 at 21:41 |
The jimmy jig/ used 1/2in ply cover with laminate both sides, hardwood telescoped rails, or 20/80 aluminium extrusions and a clamp that forces the jig rails against the frame that surrounds the table saw/ rock solid, the fence will never deviate from parallel as it it fixed to the sliding platform, In the unique aperture of the jig you can add a router or jig saw in an extra insert, these inserts are also a zero clearance over the blade
invite all table saw owners to discuss the Jimmy Jig , pros or cons
Hi
Nice to meet you after viewing your profile i am Jacinda, from (jakarta) indonesia,
i have a project discussion with you please email me on: (jacinda.seiler@yahoo.com)
