will cross-cut 8ft sheet material with the use of the outrigger which has but one line of friction along the top of the round pipe
JPEG Image -
3.74 MB -
02/04/2018 at 21:48
Preview
simple if you think about it
JPEG Image -
3.53 MB -
02/04/2018 at 21:47
Preview
The jimmy jigs lift off guard, central pivot is automatic
JPEG Image -
2.75 MB -
02/04/2018 at 21:44
Preview
very simple cross-cut -sled on the Jimmy Jig
JPEG Image -
3.33 MB -
02/04/2018 at 21:43
Preview
Jimmy jig in Spanish
JPEG Image -
3.15 MB -
02/04/2018 at 21:41
Preview
Jimmy jig in Portuguese
JPEG Image -
5.42 MB -
02/04/2018 at 21:39
Preview
jimmy jig in Russian
JPEG Image -
3.48 MB -
02/04/2018 at 21:37
Preview
understanding the jimmy jig in English
JPEG Image -
4.00 MB -
02/04/2018 at 21:36
Preview
strong clamp on the jimmy jig's fence/ adjustable with bolts in the t-track
JPEG Image -
2.74 MB -
02/04/2018 at 21:33
Preview
00004.MTS
lift off secondary fence
mpeg-tts -
33.38 MB -
02/04/2018 at 21:28
Download
2 jimmy jig styles one with a circular saw twined with a Bosch table saw
JPEG Image -
297.02 kB -
02/03/2018 at 02:23
Preview
roller hold downs-in's on the fence
JPEG Image -
89.61 kB -
02/03/2018 at 02:22
Preview
automatic push block slides on the fence
JPEG Image -
1.81 MB -
02/03/2018 at 02:08
Preview
secondary sliding sled, slide on the left end on a telescoped rail
JPEG Image -
1.70 MB -
02/03/2018 at 02:05
Preview
00003-001.MTS
lift of the secondary fence
mpeg-tts -
34.97 MB -
02/03/2018 at 02:01
Download
cheapie sliding sled
JPEG Image -
304.72 kB -
02/03/2018 at 01:44
Preview
add this with a router in the aperture
JPEG Image -
695.09 kB -
02/03/2018 at 01:43
Preview
The forty ninner
JPEG Image -
2.19 MB -
02/03/2018 at 01:41
Preview
the on the fence pusher
JPEG Image -
2.08 MB -
02/03/2018 at 01:40
Preview
how to expand a table saw rip width from zero to 49in.
JPEG Image -
2.80 MB -
02/03/2018 at 01:37
Preview
very simple but very effective cuts to 4ft on centre
JPEG Image -
2.34 MB -
02/03/2018 at 01:35
Preview
says it all
JPEG Image -
3.69 MB -
02/03/2018 at 01:34
Preview
read it
JPEG Image -
739.55 kB -
02/03/2018 at 01:32
Preview
00003.MTS
the saw blade zero clearance insert slides under the stationary fence allowing the blade close contact with the fence
mpeg-tts -
34.88 MB -
02/03/2018 at 01:26
Download
00004-001.MTS
The Original from 1980
mpeg-tts -
46.59 MB -
02/03/2018 at 01:11
Download
00002-001.MTS
the copy by the BIG BOUYS
mpeg-tts -
18.38 MB -
02/03/2018 at 00:37
Download
more of the BIG BOUYS, easy to see macduff's invention
JPEG Image -
1.64 MB -
02/02/2018 at 23:53
Preview
this is a copy by the BIG Bouys
JPEG Image -
2.15 MB -
02/02/2018 at 23:51
Preview
the original concept born 1980
JPEG Image -
2.41 MB -
02/02/2018 at 23:50
Preview
How to rip on the jimmy jig
JPEG Image -
798.36 kB -
02/02/2018 at 23:47
Preview
The lift off guard and see through with splitter that follows the curve of the blade
image/jpeg -
2.39 MB -
02/02/2018 at 23:44
Preview
How it works on top of and existing table saw
image/jpeg -
900.37 kB -
02/02/2018 at 23:30
Preview
