915 MHz Sensor Node:
#include <SPI.h>
#include <AIR430BoostFCC.h>
#include "I2C_SoftwareLibrary.h"
#define SCL_PIN P2_6 ///< pin for SCL
#define SDA_PIN P2_7 ///< pin for SDA
SoftwareWire Wire(SDA_PIN, SCL_PIN);
#define ADDRESS_LOCAL 0x02
#define ADDRESS_REMOTE 0x01
#define DROPLET
#define _address 0x40
//#define NODE_NUM 4
struct sPacket
int node;
float temp; // Local node address that message originated from
float rh; // Local node message [MAX. 59 bytes]
struct sPacket txPacket;
void setup()
txPacket.node = 9;
pinMode(GREEN_LED, OUTPUT);
digitalWrite(GREEN_LED, HIGH);
pinMode(RED_LED, OUTPUT);
digitalWrite(RED_LED, LOW);
Radio.begin(ADDRESS_LOCAL, CHANNEL_1, POWER_MAX);
digitalWrite(RED_LED, HIGH);
void loop()
Wire.beginTransmission(_address);
Wire.write(0xE5);
Wire.endTransmission(false);
//Wire.endTransmission();
//delay(20);
Wire.requestFrom(_address, 2);
while (Wire.available() < 2);
uint16_t rhMS = Wire.read();
uint16_t rhLS = Wire.read();
Wire.write(0xE0);
//delay(20);
uint16_t MS = Wire.read();
uint16_t LS = Wire.read();
//Serial.println(MS<<8LS,DEC);
//Serial.println(MS,BIN);
txPacket.temp = (MS<<8)+LS;
txPacket.rh = (rhMS<<8)+rhLS;
//Serial.println(t,0);
txPacket.temp=((175.72*txPacket.temp)/65536-46.85)*9/5+32;
txPacket.rh = (125*txPacket.rh)/65536-6;
digitalWrite(GREEN_LED, LOW);
Radio.transmit(ADDRESS_REMOTE, (unsigned char*)&txPacket, sizeof(txPacket));
sleepSeconds(4);
}2.4 GHz Sensor Node:#include <analog_io.h>
#include <SPI.h>
analog_io radio(P3_5, P3_6, P2_5); // P2.0=CE, P2.1=CSN, P2.2=IRQ
const uint8_t txaddr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0x01 };
SoftwareWire Wire(P3_0, P2_1);
//SoftwareWire Wire(P3_1, P1_3);
int node_num = 4;
void setup() {
SPI.begin();
SPI.setDataMode(SPI_MODE0);
SPI.setBitOrder(MSBFIRST);
radio.begin(); // Defaults 1Mbps, channel 0, max TX power
radio.setTXaddress((void*)txaddr);
void loop() {
Wire.write(0xE5);
//delay(20);
Wire.write(0xE0);
//delay(20);
float t = (MS<<8)+LS;
float rh = (rhMS<<8)+rhLS;
t=((175.72*t)/65536-46.85)*9/5+32;
rh = (125*rh)/65536-6;
radio.print("{\"id\":\"N");
radio.print(node_num);
radio.print("\",\"t\":");
radio.print(t,1);
radio.print(",\"rh\":");
radio.print(rh,1);
radio.print("}");
radio.flush(); // Force transmit (don't wait for any more data)
/*radio.print(node_num);
radio.print(":");
radio.print(t,1);
radio.print("F ");
radio.print(rh,1);
radio.print("%");
radio.flushBle(); // Force transmit (don't wait for any more data)
//radio.deepsleep();
sleepSeconds(3);
//sleep(4000);
}915MHz Hub Code:
#include <SPI.h>
#define ADDRESS_LOCAL 0x01
char escape_char = 0xFF;
struct data_packet
int node;
struct data_packet rxPacket;
void setup()
// The radio library uses the SPI library internally, this call initializes
// SPI/CSn and GDO0 lines. Also setup initial address, channel, and TX power.
pinMode(LNA_EN, OUTPUT);
pinMode(PA_EN, OUTPUT);
pinMode(HGM, OUTPUT);
digitalWrite(LNA_EN, LOW);
digitalWrite(PA_EN, LOW);
digitalWrite(HGM, LOW);
//pinMode(P3_6, INPUT);
// pinMode(P3_5, INPUT);
Serial.begin(38400);
void loop()
digitalWrite(LNA_EN, HIGH);
digitalWrite(HGM, HIGH);
unsigned char numbytes = Radio.receiverOn((unsigned char*)&rxPacket, sizeof(rxPacket), 1000);
if (numbytes>0){
writeSof();
Serial.print("{\"id\":\"D");
Serial.print(rxPacket.node);
Serial.print("\",\"t\":");
Serial.print(rxPacket.temp);
Serial.print(",\"rh\":");
Serial.print(rxPacket.rh);
Serial.print("}");
writeEof();
void writeToHub(char c)
if (c==escape_char){
Serial.write(escape_char);
Serial.write(c);
void writeEof()
Serial.write(0x02);
void writeSof()
Serial.write(0x01);
}2.4GHz Receiver Code:
#include <SPI.h>
analog_io radio(P2_6, P2_7, P2_5); //CE csn irq
const uint8_t rxaddr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0x01 };
void setup() {
SPI.begin();
radio.setRXaddress((void*)rxaddr);
radio.enableRX(); // Start listening
void loop() {
char inbuf[33];
while (!radio.available(true))
if (radio.read(inbuf)) {
writeSof();
Serial.print(inbuf);
writeEof();
void writeEof()
Serial.write(0x02);
void writeSof()
Serial.write(0x01);
}Electric Imp Device Code:// Create a message buffer
local msg = ""
local msgN = ""
local escape = false
local escapeN = false
local escape_char = 0xFF
local sof = false
local sofN = false
local reconfigs = 0
// A function that is called everytime that the UART receives a byte
function serialRx() {
local i = 0
local c = 0
//Pull a byte from the UART FIFO
local uart_blob = hardware.uart57.readblob()
for (i=0;i<uart_blob.len();i++)
c = uart_blob[i]
if (escape)
switch (c){
case 0x01:
sof=true
msg = "";
break
case 0x02:
//agent.send("receiveData",msg+hardware.getdeviceid())
agent.send("data",msg)
//agent.send("log_rssi",imp.rssi())
msg = "";
sof=false
break
case 0xFF:
if (sof){
msg=msg+format("%c",c);
break
escape = false
else
escape = true
else {
if (sof){
function serialRxN() {
local i = 0
local c = 0
local uart_blob = hardware.uart12.readblob()
c = uart_blob[i]
if (escapeN)
switch (c){
case 0x01:
sofN=true
msgN = "";
break
case 0x02:
agent.send("dataN",msgN)
msgN = "";
sofN=false
break
case 0xFF:
if (sofN){
msgN=msgN+format("%c",c);
break
escapeN = false
else
escapeN = true
else {
if (sofN){
// Setup hardware UART with serialRx event to receive bytes
hardware.uart57.configure(38400, 8, PARITY_NONE, 1, NO_CTSRTS, serialRx);
hardware.uart12.configure(38400, 8, PARITY_NONE, 1, NO_CTSRTS, serialRxN);
//agent.send("log_msg","device booted: "+hardware.getdeviceid().toupper())Electric Imp Agent Code:local private = "..."
local public = "..."
function processJson(json) {
local data = http.jsondecode(json)
//server.log(json)
if (data.t > 0)
local node_id = format("%c",data.id[1]).tointeger()-1
// Prepare the phant headers
local phantHeaders = {"Phant-Private-Key": private, "connection": "close"};
// Create a post request
local req = http.post("http://lgbeno.analog.io/input/"+public, phantHeaders,http.urlencode(data));
req.sendsync().statuscode;
function processJsonN(json) {
//server.log(json)
if (data.t > 0)
device.on("data",processJson)
device.on("dataN",processJsonN)Javascript Web Page:
Luke Beno
