Got my boards from Seeed Studio. They apparently had an issue with my drill file and replaced the slots with pads. That's the OPPOSITE of what I wanted for HV creepage distance. A dremel makes it so that I can at least use the board as a prototype. Assembly has begun. The power supply works and the Teensy LED blinks. Now to populate the other 90% of the components!
mauswerkz
