connection diagram
The construction is very easy. The connection LCD_RST to VCC saves the port pin we need for the input.
| -| t13 |- | VCC (3V) / LCD_RST | |
| LCD_SDIN | -| |- | LCD_SCE |
| LCD_SCLK | -| |- | LCD_DC |
| GND | -|______|- | INPUT(Button - GND) |
Usage
• start editor: connect PortB0 to ground / hold the button (at startup)
• button input: short-NEXT; long-OK
• organisation: Sites->Line->Word->edit Word->Save
• chancel: disconnect from battery
Thomas Baum
JohnsonFarms.us
iSax
gokux
ammarbhayat28
How much clicks is takes to program "Hello World" greeting? :-)
I like the project. Can you edit the editor itself? Can you move the PC to edited region in order to execute the entered program?
