A risk assessment tool has been coded based on a short list of questions to assess the risk of developing type 2 diabetes over the next ten years. Example Arduino code below:
char incomingLetter;
void setup() {
Serial.begin(9600);
void loop() {
Serial.println("TYPE 2 DIABETES RISK ASSESSMENT");
Serial.println("");
int score = 0;
char * a_to_d[] = {"a) ", "b) ", "c) ", "d) "};
char * questionary[8][5] =
{"1. AGE", "Under 45 years", "45-54 years", "55-64 years", "Over 64 years"},
{"2. BODY-MASS INDEX, BMI = MASS [kg]/(HEIGHT [m])^2", "Lower than 25 kg/m^2", "25-30 kg/m^2",
"Higher than 30 kg/m^2"},
{"3. WAIST CIRCUMFERENCE BELOW RIBS", "Men: Less than 94 cm, Women: Less than 80 cm",
"Men: 94-102 cm, Women: 80-88 cm", "Men: More than 102 cm, Women: More than 88 cm"},
{"4. DAILY AT LEAST 30 MINUTES PHYSICAL ACTIVITY?", "Yes", "No"},
{"5. HOW OFTEN DO YOU EAT VEGETABLES OR FRUITS?", "Every day", "Not every day"},
{"6. HAVE YOU EVER TAKEN MEDICATION FOR HIGH BLOOD PRESSURE ON REGULARY BASIS?", "No", "Yes"},
{"7. HAVE YOU EVER BEEN FOUND TO HAVE HIGH BLOOD GLUCOSE?", "No", "Yes"},
{"8. HAVE ANY OF THE MEMBERS OF YOUR IMMEDIATE FAMILY BEEN DIAGNOSED WITH DIABETES TYPE 1 OR 2?",
"No", "Yes: grandparent, aunt, uncle, first cousin (but no own parent, sister, brother or child)",
"Yes: own parent, sister, brother or child"}
int questionary_col_index[] = {3, 2, 2, 1, 1, 1, 1, 2};
int score_table[8][4] =
{0, 2, 3, 4},
{0, 1, 3},
{0, 3, 4},
{0, 2},
{0, 1},
{0, 2},
{0, 5},
{0, 3, 5}
for(int i = 0; i < 8; i ++) {
for(int j = 0; j < questionary_col_index[i] + 2; j ++) {
if(j > 0) Serial.print(a_to_d[j - 1]);
Serial.println(questionary[i][j]);
Serial.println("");
while(1) {
user_input();
if(incomingLetter == 'a') {
score += score_table[i][0];
reset_input();
break;
if(incomingLetter == 'b') {
score += score_table[i][1];
reset_input();
break;
if(questionary_col_index[i] > 1 && incomingLetter == 'c') {
score += score_table[i][2];
reset_input();
break;
if(questionary_col_index[i] > 2 && incomingLetter == 'd') {
score += score_table[i][3];
reset_input();
break;
char * risk_assessment[] =
"estimated ",
"LOW:",
"1 in 100",
"SLIGHTLY ELEVATED:",
"1 in 25",
"MODERATE:",
"1 in 6",
"HIGH:",
"1 in 3",
"VERY HIGH:",
"1 in 2"
Serial.print("THE RISK OF DEVELOPING TYPE 2 DIABETES WITHIN 10 YEARS IS ");
if(score < 7) {
Serial.println(risk_assessment[1]);
Serial.print(risk_assessment[0]);
Serial.print(risk_assessment[2]);
if(score > 6 && score < 12) {
Serial.println(risk_assessment[3]);
Serial.print(risk_assessment[4]);
if(score > 11 && score < 15) {
Serial.println(risk_assessment[5]);
Serial.print(risk_assessment[6]);
if(score > 14 && score < 21) {
Serial.println(risk_assessment[7]);
Serial.print(risk_assessment[8]);
if(score > 20) {
Serial.println(risk_assessment[9]);
Serial.print(risk_assessment[10]);
Serial.println(" will develope disease");
Serial.println("");
void user_input() {
if(Serial.available()) {
delay(50);
while(Serial.available()) {
incomingLetter = Serial.read();
void reset_input() {
incomingLetter = ' ';
