ctc_mk8_extruder_right_base.stl
material feeder part 1 (light green 3D printed part)
Standard Tesselated Geometry -
99.59 kB -
02/04/2018 at 18:02
Download
ctc_mk8_extruder_right_lever.stl
material feeder part 2 (light green 3D printed part)
111.90 kB -
02/04/2018 at 18:02
Download
feeder_motor_mount (1).stl
Feeder motor mount (light blue 3D printed part) After a while of printing you pause the print and insert the nut in your 3D printed part. You will see when the nut hole appeare and when it is starting to close then insert nut for bowden tube.
72.15 kB -
02/04/2018 at 18:00
Download
Duct.stl
Fan duct (dark green 3D printed part)
110.24 kB -
02/04/2018 at 18:00
Download
Bowden_clamp_v2.stl
hotend mount part 2 (white 3D printed part)
251.84 kB -
02/04/2018 at 17:59
Download
Bowden_mount_v2_with_endstop.stl
Hotend mount part 1 (white 3D printed part)
514.73 kB -
02/04/2018 at 17:58
Download
