You should start in the below order. Also if you have the wallet on a Windows OS you will probably need to adjust your Windows protection settings.
Magi wallet
Magi pool pi3 info
Raspberry pi3 magi miner
I wanted to figure out a way to mine using just a Raspberry Pi3 without the USB asic miners.
Magi wallet
Magi pool pi3 info
raspberry pi3 magi miner.txtRaspberry Pi3 setupplain - 1.29 kB - 02/05/2018 at 00:04 |
Magi pool pi3 info.txtSign up for Magi mining poolplain - 989.00 bytes - 02/05/2018 at 00:03 |
Magi wallet.txtSetup the Magi crypto walletplain - 1.53 kB - 02/05/2018 at 00:03 |
