Tests showed when the Hitec HS-311 was at 150Hz & buzzing, it sucked 900mA. At 100Hz, it didn't buzz & dropped back to 200mA, so definitely check the PWM frequency. Still, a brushless servo would get the ultimate range.
An 8.35 mile drive with nothing but a speaker & no headlights burned 3200mAh or 383mAh/mile. Still far below the good old days. Steering was rock solid with P 200 D 200. D had to be a bit lower without the camera. Range anxiety makes it difficult to replace with a larger vehicle until the source of the increased burn rate is known. The ideal vehicle would go 30 miles using 13500mAh.
