After another 8.4 miles & 4463mAh, it died. It burned 531mAh/mile. 2.6 of those were in 19m21s, slightly slower than the last 2.6 mile speed run, but also heading upwind.
The transmission was finally opened & cleaned. The counter gear & pinion gear had a lot of loose dirt & were dry. The differential gear was lubed & clean. The holes for lubrication were hard to seal. Electrical tape was replaced with a more tenacious adhesive, which might have liquefied & gotten into the gears, leading to the sudden drop in range. The source of the dirt is mysterious. Despite not sticking, electrical tape might have actually been a more effective seal.
The Tacon 2400kV is quite a well made beast, but bolts encasing it have corroded. According to blog posts, when the lunchbox was new, the brushless motor burned 283mAh/mile. The brushed motor burned 413mAh/mile. All the conversions to increase the payload cost it.
3 years of inferior steering controllers vs new tires.
A rare pristineness worth documenting.
Washing robots in this century is as important as washing cars was, in the last century.
