11 miles burned 3682mAh or 334mAh/mile. It carried 14oz of food back, so it benefited greatly from the transmission rebuild & new tires. Dialed the wheel diameter to 109mm with no obvious change in speed.
The next 11.25 miles were manely flat, without headlights, & burned 3608mAh. Did some 200m intervals. It did feel a little hotter at 109mm. Drove through a puddle & the motor stopped. Managed to get it going again after waiting a long time for it to cog. Eventually, it wouldn't restart & the CPU was dead. It was the 1st time such a puddle completely disabled a vehicle. It must have reached into the CPU compartment. Just a dot of water on a reset pin can disable it. Another problem area is the bootloader, which is hung by any stray signals entering the RX pin, but this appeared to be a reset issue. It was a very slow 1.5 mile walk before the CPU booted again.
The previous puddle encounter caused the tachometer to fail. It had to be pulse driven until it finally worked again.
