This one died 5 miles from home, so it was another 5 mile walk back with the robot using its bluetooth interface. It was here when the lion kingdom realized the bluetooth interface should have fully proportional steering with very low deadband & a way to detect when the driver's paw stops moving due to a GUI bug.
It momentarily worked after cleaning off the pads, but completely failed after a full reflow. The lion kingdom has never reflowed a CC1101 without killing it. The moral of the story is they can't be reflowed.
The CC1101 got a hot glue blob which has proven a very effective barrier on the raspberry pi zero's. That operation revealed all the other problems which arise after a few hundred miles.
Cracking of the chassis continued, so it got a thorough teflon doubler.
The nylon straps which proved so effective in the past became shredded very quickly. The decision was made to try expensive Vibram rubber in a conic section.
