Finger guard
Open the door with your fingerprint and control it with telegram bot
Use your finger to open the door.
It is based on raspberry pi 1, with UART fingerprint scanner and a simple relay.
It is not the final product, it's still in development.
This project is based on Raspberry pi 1 and UART fingerprint scanner.
It is very easy to build and control.
Fingerprint scanner is able to store 1000 fingerprints.
You can add new one, delete or even download image of scanned fingers.
Everything is controlled via telegram bot / or web-interface(in future)
Adding new finger is very easy:
*Push "Add new finger" in telegram bot and place your finger to scanner two times
*Write the name of the person, and it will be stored in text file with the number of the fingerprint( it is need to delete specific finger. )
* As soon as you added new finger, push "Start search", place your finger and this time relay will change its state
* Connect relay to door and you do not need any keys no more, use your finger to enter.
Preparation
For this you will need an RPI1/2/3 (it doesn't matter)  with the Raspbian installed. You can get it here: https://www.raspberrypi.org/downloads/raspbian/
Boot up Raspbian and make some configuration.
sudo cp /boot/cmdline.txt /boot/cmdline_backup.txt
Edit the file:
sudo nano /boot/cmdline.txt
Delete any parameters involving the serial port "ttyAMA0" or "serial0" if it exist, which in this example is:
console=ttyAMA0,115200
Which gives:
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
Press CTRL+X to exit and save .
Next, you have to disable the serial getty service:
sudo systemctl stop serial-getty@ttyAMA0.service
sudo systemctl disable serial-getty@ttyAMA0.service
Enable UART
Enabling UART with minimum core frequency:
pi@raspberrypi:~ $ sudo nano /boot/config.txt
# Enable UART
enable_uart=1
Enabling UART with maximum core frequency:
# Enable UART
enable_uart=1
force_turbo=1
Install Python library for ZFM fingerprint sensors
~$ echo "deb http://apt.pm-codeworks.de wheezy main" | sudo tee -a /etc/apt/sources.list
~$ wget -O - http://apt.pm-codeworks.de/pm-codeworks.de.gpg | sudo apt-key add -
~$ sudo apt-get update
~$ sudo apt-get install python-fingerprint
~$ sudo usermod -a -G dialout pi
~$ cd /usr/share/doc/python-fingerprint/examples/
In my case i host telegram bot apart from rpi, so i created ssh secure public key to communicate with raspberry.
Login to server where the telegram bot is hosted:
server1:~# cd /root/
server1:~# ssh-keygen -t dsa
Generating public/private dsa key pair.
Enter file in which to save the key (/root/.ssh/id_dsa): <PRESS ENTER TO ACCEPT DEFAULT>
Created directory '/root/.ssh'.
Enter passphrase (empty for no passphrase): <PRESS ENTER FOR NO PASSPHRASE>
Enter same passphrase again: <PRESS ENTER FOR NO PASSPHRASE>
Your identification has been saved in /root/.ssh/id_dsa.
Your public key has been saved in /root/.ssh/id_dsa.pub.
The key fingerprint is:
41:03:aa:dc:cc:b9:39:50:65:bc:ee:7b:36:d2:64:7a root@server1
Copy the public key from 'server1' to 'raspberrypi'...
server1:~# scp /root/.ssh/id_dsa.pub 192.168.0.2:/root/.ssh/authorized_keys
You can test it with
ssh root@192.168.0.2
Create Telegram...
enroll.py
add new finger
x-python - 1.97 kB - 02/06/2018 at 08:42
Download
search.py
x-python - 1.96 kB - 02/06/2018 at 08:42
Download
delete.py
x-python - 1.09 kB - 02/06/2018 at 08:42
Download
  • 1 × Raspberry Pi 1 You can use RPI 2-3 as well
  • 1 × Relay Power Supplies / Uninterruptible Power Supplies (UPS)
  • 1 × Fingerprint UART scanner
View project log
