Active Linear Multi Element Sonar Array (ALMESA)
Active multi-beam sonar for robots and visualization... on the cheap.
I recently bought an OpenROV kit. Yes I could have rolled my own, but it's always nice to have a starting point when you don't know exactly what you're doing. I always find its easier to tear something that works apart to figure out how to build one that's better.
After building it (haven't tested it in water yet) I thought "what else can be done with this platform?"
The 8th thing to come to mind was seabed mapping. Dreams of grandeur and treasure hunting may have played a factor in my decision to pursue this particular cause. It's refreshing to go off in search of something and not even know what it is you are searching for. My first set of searches focused on sidescan sonar as I thought that was what they used to find things on the seabed and was what I was looking for. Close but not it.
Further searches and papers pointed me to multibeam sonar swathes which is indeed what I was after and from what I see, doesn't exist for the hacker/maker crowd. I aim to fix this.
I think it's important in projects to layout a set of goals and features that define when your project if finally feature set complete. The important parts:
  1. Range - should be as high as possible. We're going to aim for 40m operational.
  2. Visualization - of data is as important as getting it. Ease of access to the data is critical. API or easy output is required.
  3. Resolution - It doesn't do any good if we cant distinguish things. 1m resolution or better at operational limits.
  4. Samples - 60 beam sweep with raw data output to waterfall/C type display
The "I really want these" parts:
  1. 100m operational distance in water.
  2. GPS tie in (topside component) + onboard IMU
  3. OpenROV easy add-on and tie in with ROVCockpit
  4. OpenROV mount
  5. 0.5m resolution @ 100m
  6. Multi Pass per sweep (double data rate with averaging for better accuracy)
  7. Exportable to raw format for conversion to 3d heightmap models (proto typed in Unity 5)
  8. 200+ beam sweep for higher resolution
  9. Fish rejection
  10. Amplitude detection (able to determine how hard an object is in relation to it's surroundings)
  • 1 × arduino uno
  • 4 × sn-04
  • 1 × Square Aluminum Tubing
  • Working Waterfall Display
    eimer.josh0 • 03/22/2015 at 19:38 • 0 comments
    Had some time this weekend to tweak the vb.net display. Data points are displayed as bitmaps on a working waterfall display. Further code cleanup is required but it's pretty efficient as is. No more crashes after 250 data points are collected and no more flickering as the bitmaps are handled by the form.paint event.
    On other fronts, I'm considering these vibration sensors as my active elements. https://www.sparkfun.com/products/9196 I don't know how well they would work though for this application. I will have to order one and try it.
  • There should be a private section on here for notes... sketchbook.io anyone?
    eimer.josh0 • 03/21/2015 at 17:57 • 0 comments
    Not really a log but a place for me to dump some research material.
    Below material from: http://www.radartutorial.eu/
    Phase-increment Calculating
    The phase shift Δφ between two successive elements is constant and is called phase-increment. How large is this phase shift to reach a certain value of the beam steering?
    A linear arrangement by isotropic radiating elements is looked at.
    Die Grafik zeigt mehrere Strahler, die mit einer jeweiligen Phasendifferenz abstrahlen und einer grafischen Herleitung der Phasenverschiebung.
    x = d · sin Θs
    • A radar set works with a wavelength of λ=10 cm.
    • The distance between the radiating elements is 15 cm.
    • We can neglect the propagation time differences by the feeder.
    • The beam steering shall be Θs= 40°.
    Task:
    • Which value shall have to have the phase shifter no. 8 (on the left side) to get this beam steering?
    We start with the calculation of the phase-increment.
    Because of the trigonometrical function we need a calculator anyway: Δφ =(360°·15 cm/10 cm)·sin(40°) = 347.1°.
    This means the radiating element no. 8 needs the phase shift value φ8 = 7 · 347.1 = 2429.7°.
    On reason of the periodicity of the sine function a phase shifting of n·360° is the same as 0°. Therefore we can as long as deduct 360° till there is a angle between 0° and 360° of the result. We get therefore for the phase shifter number 8 (left corner) a phase shift value of φ8 = 269.7°.A part of this phase shift is realized by the delay in the feeding line yet.
  • Higher Resolution Proof of Concept
    eimer.josh0 • 03/18/2015 at 01:04 • 0 comments
    First set of sensors arrived yesterday from Amazon. 20 minutes of soldering later they are hooked up to the arduino. I had time over the weekend to write the code to drive them all and return the values in a defined format
    sample: [04]:[67]:[45]:[90]\r\n
    I also rewrote the vb.net application to handle the data as each line and optimized the code further. I am now working with bitmaps instead of the original hacked together draw a panel and then fill with smaller panels. Should have the benefit of easily marking things on the waterfall and easier to save to a data file. Bandwidth is also a concern with getting fast sample rates rendered on the screen. Using the graphics library will be faster than the original panel solution and has the benefit of being able to stream data into the view.
    To reduce testing errors the sensors are mounted linearly on an aluminum square tube, wire lengths are kept to a minimum. Each unit (PCB) is spaced 5cm apart for a very uniform look. Each unit is mounted in parallel with the aluminum tube, which results in a more uniform test. Each sensor is isolated from the aluminum tube with electrical tape which should help reduce any additional resonance from the nearby sensors being transmitted through the backing.
    The test unit looks a little unrefined but the test data looks good. With an effective 4 pixel sweep over about 30cm and no additional attempts to compile multiple sweeps or higher sampling or beam shaping, I can discern my desk, coffee cup, and monitor base at about 60 cm distance.
    I'm checking with the local college lab if they have a laser vibrometer for more precise testing that will be required once phased beamshaping is implemented.
    Additional sr04 sensors from ebay are still on the way. I will need to build some hardware logic to address the 14 sensor array from the uno. I'm concerned the uno may be too slow or rather the combination of uno and sr04 sensors will be to slow to be practical, however as an extended proof of concept I think it will work sufficiently.
    These are the transducers I am considering to build into the active array: http://www.ebay.ca/itm/1pc-Ultrasonic-Sensors-Integrated-Transceiver-Waterproof-Diameter-16MM-/191136732745?pt=LH_DefaultDomain_0&hash=item2c80a31649
    I am liking their size, availability and that they are pre-waterproofed; less thrilled at the price. They will be embedded in a non resonating material for ease of mounting and consistency. I am currently considering silicon as it has the benefit of being able to remove the transducers from it easily and it should absorb additional vibration from the transducers reducing co-location interference and letting us scan at a faster rate.
    Thanks for reading!
  • The Dream
    eimer.josh0 • 03/14/2015 at 06:00 • 0 comments
    "It came to me in a dream and I forgot how it worked in another..."
    How hard can it be to visualize sound. Really? No? No one on the internet builds this? That's stupid! Screw it, I'll build one. How hard can it be?
    And so it begins. I'm not starting this project with nothing to show already I think that's foolish. But I do know that I know almost nothing about audio engineering or electronic design and this is going to be a learning experience for me and my wallet... probably.
    I started off by building a vb.net waterfall type project that simply colours squares (pixels) for each sample that it receives via comm port from the Arduino Uno and it's hilariously badly wired sr-04 sensor I pulled off my quadcopter. (Vibrations and ultrasonics apparently don't play nice together)
    Some tweaking later on colours and double translation math has a working visualizer for the data streaming from the Arduino. Proof of concept complete. Lets build a small scale prototype to better fleshout the concept and get some better/more usable imagery on the waterfall. 10 sr-04's ordered from Ebay. (Edit: Damn 4 weeks... ordered 3 more from Amazon with prime, they get here Monday)
    Now how do we narrow the sample beams down to get better resolution? I mean, I can see when I sweep it past my monitor that the monitor surface is above the wall surface. But I know what I'm looking for. It doesn't do much good if you didn't know what to look for. Wikipedia says that the US Navy's top of the line (in 1960s) swath sonar used 61 beams at 1 degree precision. How did they get 1 degree precision on sonar? Which led me to the joys of phased sound arrays and directional sound with some crossover on rf theory. Great more stuff that is black magic to me... Also for note, a 6 degree beam ultrasonic sensor is nearly $130.00 USD.
    Now I'm left wondering until next week how I'm going to trigger ultrasonic pulses close enough together to form the precise wave front that I need to get anywhere near the precision of 1 degree. Modern arrays have a beam resolution of 0.016 degrees!.
    I assume building something in hardware is the best way to tackle this. Expensive systems seem to use a flat plate that resembles a solar panel. I assume it's an array of pizeo drivers in a low/non resonating substrate. I don't hope to achive their results, I'll settle for far less. I figure an array of 60 scanning transducers, with an extra one for wave forming/limiting on each end. A linear line of 61 transducers on both sides. (total count is 184 individual transducers fired in sets of 5) Probably means I'll be ordering transducers to buildup a large grid and figuring out some way of either using a few transducers to fire a ping and the bulk of them to listen or figuring out how to multiplex all of them. Probably some fancy function generators that I don't know how to build yet. Amplifiers and Gain control. (My giant book from element 14 has those covered though)
    I'll test out multiple pings with a JSON style return on serial and see if the images I get from the waterfall are more recognizable. I know in air they aren't going to be great but after I test that, I'll waterproof the boards and test in a liquid medium to see what I end up with. Post more next week. Thanks for reading!
View all 4 project logs
Cees Meijer wrote 06/12/2019 at 07:55 • point
I always wondered if these cheap 40kHz piezo transducers could be used for something like this. Really interested in you test results and if you can really detect something under water.
zakqwy wrote 03/14/2015 at 13:48 • point
Phased arrays are fascinating. Good luck--you definitely have a steep journey ahead!
