Circular Motion?
05/28/2015 at 03:26 • 0 commentsI wrote some code to produce (what I hope is) circular motion. I haven't connected the stepper motors to the CNC router yet but the movement of the motors looks like it should produce circular motion on the x, y bed.
I think the video is just about as boring as they come (with the exception of a few unboxing videos) but I wanted to share it since it was so darn difficult to program.
The program is written in assembly and uses integer math for all the calculations.
The stepper motors accelerate to their full speed but I didn't include a deceleration section of code (yet).
The program "TestMotorsPasmCircular.spin" is the top object used in this demo. The code is located in my GitHub "CncController" repository. This repository is presently very unorganized. So far I've been working on individual pieces of the overall program. I still have a lot of work combining these pieces together.
Mini Update, Dual Stepper Control
05/03/2015 at 18:14 • 0 commentsI wrote some assembly code to accelerate and decelerate two stepper motors. The acceleration profiles of both motors should be such as to produce linear motion (at least I think it will).
My code is now available from my GitHub account under "CncController."
The "TestMotor" object is the object I used to test the motor control algorithm.
Different Hardware
04/26/2015 at 07:59 • 0 commentsI couldn't get the original stepper driver to work even when using level shifters to convert the 3.3V logic to 5V logic.
Someone on the Parallax forum mentioned the DRV8711 stepper driver so I decided to give the DRV8711 a try.
I knew programming the CNC controller wouldn't be simple but dang it, it's downright hard. I find myself taking detours as I write the program. I think "wouldn't it be nice if I could display bitmaps as well as text on the OLED screen?" So I add a way to insert a bitmap into the display buffer. (I've tried to do this in the past and failed. This time I succeeded. ) Then I think "wouldn't it be nice if the dark areas of the bitmap could be transparent?" So I add a way to OR the two images. (IMO this looks pretty cool.) I also added code to invert a section of the bitmap. I'll likely inverted a line of text as a way to indicate it has been selected.
Another sidetrack was making a mount for a joystick I saw in a Hackaday article. I then needed to incorporate the joystick into the CNC interface.
Here are a couple of pictures of the joystick. This first one shows the PVC cap I used prior to cutting the holes. I added the Dr. Pepper can to provide scale.
This next photo shows the joystick mounted to the PVC cap.
I confess to not really needing another joystick, but I thought this one looked really cool. Here's a link to the Aliexpress seller.
I made a video showing the OLED displaying both text and graphics. The video also shows how I was able to invert a section of the screen.
Since I'm not using the original stepper driver hardware, I decided to switch the rest of the electronics hardware too. I'm using a different Propeller control board and a different display than I previous used for this project. This current configuration of hardware is easier to modify than my previous hardware.
The NTSC video display I previously used required my using a second Propeller chip as a graphics slave. The smaller OLED display can be driven from same Propeller chip as the one I'm using to control the stepper motors so I'm now just using one Propeller microcontroller.
The Main Hardware
03/16/2015 at 23:00 • 0 commentsI took a couple of photos of the CNC frame.
Besides the electronics I earlier photographed, there are also some other parts in shown in the above photos. These include the router mount, stepper motors and other miscellaneous parts.
I'm using the third stepper motor to test the electronics so it's not included in the box of parts photo.
There's also a piece of heavy plywood which will provide the base of the work area. A piece of sacrificial MDF will be on top of the plywood.
While the overall frame has been built, I haven't tightened all the bolts yet. I want to be able to move the components as I tighten everything in place to make sure there isn't any binding.
I've had these parts for over a year. I'm excited about the prospect of finally getting this thing up and running. IMO, it's a pretty nice machine and it's a shame to have it sitting idle.
3.3V Logic Isn't Enough
03/16/2015 at 04:17 • 0 commentsI began work on this project again today after having set it aside for about a year.
My first attempt to drive a stepper motor wasn't successful. After checking the wiring to make sure the signals from the Propeller were reaching the drive electronics, I then monitored the signal while the program was running but without connecting the Propeller to the drive electronics. While disconnected, the step signals from the Propeller were a nice 0V to 3.3V pulse. When the signal was connected to the drive electronics I found the signal line no longer produced a nice consistent pulse. I'm pretty sure the optocouplers can't be driven with a 3.3V signal.
I'll need to use some sort of level shifter to boost the 3.3V signal from the Propeller to a 5V output the drive electronics can use.
Duane Degn
