Raster 2 Laser GCode generator
Raster 2 Laser GCode generator is an extension to generate Gcode for a laser cutter/engraver (or pen plotter).
Raster 2 Laser GCode generator is an extension to generate Gcode for a laser cutter/engraver (or pen plotter), it can generate various type of outputs from a simple B&W (on/off) to a more detailed Grayscale (pwm).
[Code on github https://github.com/305engineering/Inkscape ]
USAGE:
1) Resize the inkscape document to match the dimension of your working area on the laser cutter/engraver (Shift+Ctrl+D)
2) Draw or import the image then To run the extension go to: Extension > 305 Engineering > Raster 2 Laser GCode generator
3) Play!
EXAMPLE:
View project log
Technical John wrote 09/12/2022 at 16:29 point
I believe this one will support latest Inkscape version 1.x
https://github.com/SidneyBovet/raster2laser_gcode
cllow2020 wrote 07/08/2021 at 04:31 point
goto GitHub look for "Raster 2 Laser GCode for cr3dp"
"Raster 2 Laser GCode for cr3dp" is an extension revision from Raster 2 Laser GCode generator to suit for Creality 3d print
for INKSCAPE 0.92 only
cllow2020 wrote 07/08/2021 at 04:20 point
Traceback (most recent call last):
  File "raster2laser_gcode.py", line 37, in <module>
    import png
  File "C:\inkscape\inkscape-1.1-x64\share\inkscape\extensions\png.py", line 1885
    except ValueError, e:
SyntaxError: invalid syntax
issue!! can't works
dino1963 wrote 12/15/2020 at 18:13 point
Traceback (la chiamata più recente per ultima):
  File "raster2laser_gcode.py", riga 37, in <module>
    import png
  File "C: \ Program Files \ Inkscape \ share \ inkscape \ extensions \ png.py ", riga 1885
    tranne ValueError, e:
SyntaxError: sintassi non valida
Qualcuno può aiutarmi?
mdtaha wrote 07/05/2020 at 09:45 point
    import png
  File "C:\Program Files\Inkscape\share\inkscape\extensions\png.py", line 1885
can anybody help me?
jean-marc.ariganello wrote 11/15/2020 at 09:17 point
Hello, I have the same message today. Did you fix it ? This can help me to move forward.
Thanks in advance. Regards
cllow2020 wrote 07/08/2021 at 05:08 point
popovmp29 wrote 04/10/2020 at 01:55 point
Thanks!!! Thanks!!! Thanks!!!
James wrote 10/21/2018 at 06:22 point
Can someone explain what B/W threshold and Grayscale resolution values mean?]
Naruto128 wrote 03/24/2018 at 05:28 point
hello, thank you very much for the plugin. How ¿can I select the minimum and maximum of the laser??
Curtis wrote 02/03/2018 at 02:03 point
I could use a little help, I'm pulling an image off the internet for testing as I wanted to see how well it would shade but what I was getting was almost a complete black shape. I tried various settings and still was not working. The preview that the code generates looked amazing and I thought my real results were going to match. I was wrong. Do I need to save the image as a PNG or without a background of any color. It currently had a white background. Any help would be great
Thanks. PS this is a pretty sweet plugin. I came to it for the shading feature.
Paul Candler Martinez wrote 06/24/2017 at 04:11 point
Excellent extension, great job 305 Engineering!  I use it a ton, but I wanted some extra/different functionality so I added a couple things (a dimensional test, custom header and footer scripts and a user definable max laser output power level)  Check it out at
http://www.candlercustoms.com/remix-of-305-engineering-inkscape-extension/
Big shout out to y'all.
oni305 wrote 07/17/2017 at 16:16 point
Thanks!
If you want to share your changes, you can contribute on github (or you can send me the code), I would be happy to share them.
bruce wrote 02/09/2017 at 17:55 point
Answer my own question here: Yes it works because I somehow didn't move the correct unzipped files! D'oh! I moved the files where you are told too and it shows up now.
bruce wrote 02/09/2017 at 16:22 point
Will Raster 2 Laser Gcode work with Inkscape 0.92 64bit version? I downloaded and installed the files into the "extension" folder and when I run Inkscape it doesn't show up.
nanou37500 wrote 09/13/2016 at 19:43 point
Hi,
i use the plugin on a mac too and I don't know what to type in the "export directory", May be somebody can help me
Thank you in advance
e_bettio wrote 02/15/2017 at 05:33 point
This is a very late reply, but in case you didn’t work it out or someone else is having the same problem, the path you put in is the path from the ‘Macintosh HD’ directory
In Finder, select ‘Show Sidebar’ in the VIEW drop-down menu.
Make sure your ‘Devices’ are showing. ‘Macintosh HD’ should be one of your devices. (If you just see the ‘Devices’ heading but nothing is listed underneath, hover the cursor of ‘Devices’ and ‘show’ will appear next to it. Click on ‘show’… now you should see ‘Macintosh HD’ amongst some other things).
Click on ‘Macintosh HD’
This is the directory that the plugin is looking in. So whatever path takes you to your desired directory from here, put that path in the ‘Export Directory’ space in the plugin
For me, the path is:
Users/my_name/Documents/MY PROJECTS AND HOBBIES/Laser Engraver/gcode output files
The subfolders from ‘MY PROJECTS AND HOBBIES’ on are folders I created.
e_bettio wrote 09/06/2016 at 02:16 point
Hi Oni305,
Thank you for creating this extension. I only use black/white but I have been using if for about a year now and think it’s great.
I have a couple of suggestions that could make it even better:
1. Add Z-axis coordinate. I have Z-axis control on my engraver (it’s a modified 3D printer) and I set the Z-axis to accommodate the laser focus and also the different thicknesses of the engraved material. A Z-axis setting would have to be done first to lift the laser above the material before it moves in the X and Y directions
2. Allow another ‘homing’ option at the end so the operator can set a custom code (I manually change the G28 to a G00 code to bring the work area forward, as homing the bed pushes it back so that it is harder to see/access).
3. One other suggestion: could there be a different speed setting when the laser is off? When there is a lot of empty space on the engraving, it can take a very long time to engrave as the laser travels quite slowly between engraving areas (I don’t have a strong laser so it moves slowly when engraving).
Just suggestions. Even without them, your extension is great.
oni305 wrote 09/08/2016 at 22:17 point
Thanks for the suggestions.
Actually I'm working on other projects, but when I'll have time I will add several features to this plugin  ^_^
hootyhoo wrote 07/13/2016 at 01:19 point
The projects I'm working on require the use of raster as well as vector.  For vector I've been using the Gcodetools plugin.  For raster I just started using Raster2Laser.  I'm having a problem with a 1mm difference between Gcodetools and Raster2Laser.  I am using the same template for both with a 1mm grid for positioning.  I get the exact same offset every single time.
Example:  I draw a vector based box in Inkscape and export it using Gcodetools.  i then add a bmp inside the box, spacing it exactly 1mm from all of the edges, remove the box, and export using Raster2Laser.  The end result will have the image touching the top and right sides of the box with a 2 mm gap at the bottom and left sides.
Anyone know why the 2 outputs are 1mm off from each other?
oni305 wrote 07/13/2016 at 22:35 point
i don't know, but if the offset remains constant you can correct it manually.
You can try to generate gcode from Pixel from a known position with both the plugins, to see which one have the wrong offset
morviaan wrote 05/17/2016 at 14:05 point
Hi,
maybe this is a dumb question, but when engraving in raster style, the laser is not always on, does this mean cooldowns are no longer needed, and can work for long hours?
thank you
ivgutier wrote 05/14/2016 at 23:45 point
Hi,
I've been trying to use your plugin (on a Mac) and while the extension shows up... and I do get a preview output as well as a png output of what I need... the gcode comes out as a txt file... I also tried copying and pasting it to a gcode file... and I can't get it to work...  I'm using a prusa i3 laser cutter engraver and would appreciate your or anyone's help on this pretty please!!!
oni305 wrote 05/15/2016 at 09:56 point
Hi
yes the gcode is a simple text file.
What do you use to control the machine?
ivgutier wrote 05/15/2016 at 13:51 point
I'm using Printrun/pronterface running on a prusa i3/marlin firmware... Obviously I replaced the extruder with a laser head.... and right now I'm only able to engrave edges no fills....
with your script Everything seems to run fine, but the gcode isn't accurate either... I get G00, G01 and tgerefore doesn't recognize those...
anyway, a simple find and replace function replaces all G0's for G's and so and so.... but after I've done those replacements all I get is like a shadow.... or I'm not sure how to describe it.... pronterface shows lines all over the object's area but no discernable feature....
I would greatly appreciate your help :)
oni305 wrote 05/15/2016 at 20:12 point
The Gcode is corret, the standard is G00 & G01 , if your interpter don't undersand standard gcode i can't help...
i suggest to use a better viewer for the Gcode, try this  http://www.cncedit.com/Basicviewer/
e_bettio wrote 09/06/2016 at 02:26 point
You might have worked it all out by now, but if not:
My setup is similar: Prusa i3 with a laser fitted to the extruder body. I have no problems using the g-code output files from this extension with Marlin. I haven't tried with Pronterface but see no reason why I should. All the g-codes in the output files are recognised by Marlin. I change the file name so the extension is .gcode instead of .txt, and I add a few settings for Z-axis (and a few other minor adjustments), then put it on the SD card and tell the printer to 'print' it.
nanou37500 wrote 09/13/2016 at 19:42 point
Hi,
i use the plugin on a mac too and I don't know what to type in the "export directory", May be you can help me
Thank you
georgefomitchef wrote 01/25/2016 at 12:55 point
Looking for gcodes for engravings
We are looking for gcodes for engraving to put on our web site:
http://endurancerobots.com/products/laser-cutters-accessory/gcode-samples-for-engraving-2/
we already have some on Endurance web site. So feel free to send gcodes so we can
upload them
koswix wrote 01/24/2016 at 02:01 point
Really like the plug in, are there any plans to support smoothieboards? Don't think it would take much - on smoothie the power level is set by an S parameter given with a G1 code, and the scale is 0 to 1. Exampe:
G1 X100 Y100 S0.5 for half power.
Ariel Yahni wrote 01/23/2016 at 21:29 point
Oni, love your plugging but having trouble using it. First it seems its also considering the background and will issua just a square box. Second GRBL seems to expect SXXXX and gcode from plugging is SXXX. What am i missing?
oni305 wrote 01/24/2016 at 00:46 point
Thanks.
1) Yes the puggin work on *everything* inside the document, so the firs step is to resize it.
(btw: don't use white to fill the background but leave it transparent)
2) by default GRBL use a value betwen 0 and 1000 for the spindle (S), you have to recompile GRBL editing line 246 of "config.h" and set it to 256.0 :
#define SPINDLE_MAX_RPM 1000.0 // Max spindle RPM. This value is equal to 100% duty cycle on the PWM.
