1Step 1
You need to have Python configured on your RPi.
- Install the following libraries: xmpppy, httplib2, dnspython
- download the LiV XMPP Python code from the gitHub repository listed before
- modify the code to suit your needs
Send me a message if you need any help or if you spot anything that I should improve in the code.
Here it is: https://github.com/FirstCypress/LiV/tree/S_development/software/liv
The code you are interested in resides under livXMPP directory.
It implements a XMPP agent that does this:
http://www.livpi.com/liv-pi-instant-messaging.html
LiV XMPP agent is part of this project:
Here is a brief software architecture description:
http://liv-pi-forum.1124721.n5.nabble.com/LiV-a-brief-software-guide-f67.html
You would need to spend some time to figure out how you can modify the existing code to fit your needs.
Good luck,
Alfred
Just in case this is too complex for your needs, here are a few basic examples: http://xmpppy.sourceforge.net, you can go over them first and then you can decide if you want to take the time to look into livXmpp and modify it.
Try:
sudo apt-get update
sudo apt-get install python-xmpp
This worked for me on Raspbian Jessie.
Best,
-Alfred
