1Step 1
You need to have Python configured on your RPi.
- Install the following libraries: flask, python-matplotlib (if you want to have data visualization)
- download the LiV APIs Python code from the gitHub repository listed before
- modify the code to suit your needs
Send me a message if you need any help or if you spot anything that I should improve in the code.
