A Micro Combined Heat and Power (Micro-CHP) unit capable of being transported by a single individual
The need for the microgeneration (<2.5kW) of electricity and heat in remote locations is well known and has many solutions currently in the marketplace. However, renewable energy systems are often unsuitable for this use as 'small-scale' renewables are comparably large and require significant support personnel, logistics and a robust infrastructure to operate efficiently.
This project seeks to investigate the issues of size, reliability and efficiency common to alternative energy systems by constructing and testing a heliostatic Concentrated Solar Power (CSP) microgeneration system. The complete system will be man portable, ruggedized, simple in operation, easily maintained and capable of solar thermal energy collection in addition to the generation of electrical power.
After construction, the system is to be characterized on the metrics of mass, ergonomics, system thermal efficiency, electrical generation efficiency, system reliability, manufacturability, marginal cost of production and levelized cost of energy (LCoE), often referred to as 'grid parity'. These metrics will be used to determine the appropriate deployment and market usage for a system of this nature.
The system efficiency is expected to be above industry average, as CSP system efficiencies have been found to be inversely proportional to collection area. The manufacturing methodology and system design are expected to yield grid parity benefits that exceed current electrical generation technologies in addition to marginal costs that would yield a market-competitive product.
tmk, thanks for the support. This is a concept I've been kicking around for a while; I hope you find the results interesting. At the very least I will enjoy the opportunity to finally develop the physical system and share my process.
Is solar the focus of the project or do you have any thoughts on adding other power sources in addition to the solar collector?
ICE comes to mind first but on a simpler scale, maybe something like those pots with the thermoelectric element so you could produce energy with a simple flame source? You'd need to circulate the water to keep everything at a safe operating temperature but you could add the ability to add power with simple wood / biomass fuels.
Part 1:
Solar is the primary focus as I'm looking to this project as an opportunity to generate electricity and act as a thermal reservoir in the absence of combustion fuels.
I'll have to track down the source, but I read a paper a few years back in which the researchers were determining the primary sources of light (e.g., incandescent, LED, fire, etc) by geographic region using remote sensing data in the optical spectrum. It turns out that, globally, the most common source of light on this planet is still from wood fires. (There was a HaD post recently about an individual in India with the same concerns, making PV 'lanterns' in a tupperware container)
Part 2:We're definitely on the same wavelength wrt generation. With portability being the attribute with the heaviest weight in the requirements matrix I down-selected to TEGs after an HoQ analysis in my first round trade study. (TL;DR: TEGs = better, you || me = smart)I had originally conceived the electrical generation portion of the project as a heat engine with a generator, which would have consumed a large percentage of my available mass. I'm really glad I forced myself to explore alternatives and firm up my design specifications before heading down that rabbit hole...
That said, the system would be able to extract energy from other heat sources with no modification.
Thanks for the reply. I think the approach is sound for the goals you have.
I was looking for an ICE solution for some time and stumped across this site:
www.microcogen.info
I don't think the majority of the engine information will be applicable to what you're doing but there may be some useful information in there for you.
I'm looking forward to seeing your progress.
Cheers
Thanks for the link Jesse, looks like it has some useful info on charge controllers in the solar/wind section.
I love heliostats and solar thermal in general. Looking forward to seeing where you take this.
