Just received first shipments of prototypes today. Looks good.
We are in kickStarter now:
https://www.kickstarter.com/projects/786298545/nodeusb-tinylow-costeat-your-own-dog-food-devkit-f
NodeUSB is a tiny, low cost $9, WiFi ready, ESP8266 USB dev kit for Internet of things, it comes with NodeMCU pre-installed
Found a great spot for Solar powered WiFi weather station:
My deck, it will block the rain, block the sun, and easy to mount solar panel
Pictures:
The battery with charging PCB is still naked, I am waiting for the PCB shipment so I can make the Battery Node. Stay tuned.
This is another one in front of my house, it is facing south, so lots of sun shine, 2 sensors will give me both the temperature under the sun or not.
Steps to make a WiFi weather station:
Here are the pictures:
Touch node video!
PCB have 8 headers (4 pins, 2.54mm). (With 6 different combinations )
So you connect different I2C modules (with different pin-outs) in just one Node. For example, you can use it to add both si7021 and bmp180 in your project. Sounds cool?
Also USB male and female pass-through, you can create Nodes Chain with several nodes!
Different connectors
Connect hall sensor:
Connect Relay:
Connect Soil humidity sensor:
Touch Sensor:
ds3231 RTC:
HMC5883L
Light Sensor
OLED display module:
CO sensor
LED module
PIR Sensor
LED light
Ultrasound range sensor
si7021 temperature and humidity sensor
BMP018, BMP085 barometer and temperature sensor
ds18b20
DHT22 sensor
433mHz receiver and transmitter
Use solar battery to power NodeUSB and bmp018 sensor
NodeUSB plug in USB power adapter:
Use NodeUSB to control 433mHz power switch:
UltraSound range sensor:
