Different connectors
Connect hall sensor:
Connect Relay:
Connect Soil humidity sensor:
Touch Sensor:
ds3231 RTC:
HMC5883L
Light Sensor
OLED display module:
CO sensor
LED module
PIR Sensor
LED light
Ultrasound range sensor
si7021 temperature and humidity sensor
BMP018, BMP085 barometer and temperature sensor
ds18b20
DHT22 sensor
433mHz receiver and transmitter
Use solar battery to power NodeUSB and bmp018 sensor
