Steps to make a WiFi weather station:
- soldering 90 degree 2.54mm headers onto NodeUSB
- Soldering si7021 module on 2.54mm header
- If you want to add barometer, Use quick connect wire to add bp180 module
- put into case closures
- put in USB power adapter
Here are the pictures:
