From the first work some improvements could be made and other had to be done.
The cabling had to be redone so the screen could be usable and easy to handle. I found a nice aluminum box on mini-box.com the case1c1. That box is cheap and has correct size. What's going in the box :
- The HDMI to LVDS converter
- Step Down voltage regulators
- A pair USB output for power
- Push buttons
I added another 5V Step down power supply for another pair of USB output. The goal is to control those USB to turn on or off the RasPI or other devices such as USB Powered Speaker.
The display is supported by a DELL stand. It works quite nicely, the screen is able to tilt back and forth.
The power supply is mounted on the back panel, just need a power cord and an HDMI to enjoy a movie.
The push buttons are not yet active, the PIC16F1455 needs to be reprogrammed to handle them. The PIC16F1455 will also act as a Virtual Com Port to control the screen via USB.
Box wiring
Back Panel
Display and side control
