Initial ideas:
- Each slave will be equipped with a microphone and a speaker. Communication will be through a call/response sort of deal. I'll have to get some hardware built before I can experiment and figure out the best way to do this. I may need to add IR sensors to keep everything synced up...
- Master will be in charge of recording a waypoint when any slave is clicked, as well as the distance to said slave, tyhe name of the slave and any other relevant data like current time etc etc.
- Everything will have to be robust for use in the bush, and low power enough for long sampling trips. Solar charger anyone?
johnowhitaker
Should still do the job.
Frank Buss
Sander van de Bor
Simon Merrett
