I wasn't happy with the opening in the clock front so i removed the front panel and bought a new multiplex 3.6mm panel (0,20 euro cents!). Cut the correct opening in the panel using an jigsaw.
Sanded the case and used filler to touch up some damaged parts.
SephenDeVos
