Modifying the clock case
A project log for Internet Split Flap Weather Clock
Internet controlled weather station that shows the current weather with a split flap display.
sephendevosSephenDeVos • 03/24/2015 at 10:20•0 Comments
I wasn't happy with the opening in the clock front so i removed the front panel and bought a new multiplex 3.6mm panel (0,20 euro cents!). Cut the correct opening in the panel using an jigsaw.
Sanded the case and used filler to touch up some damaged parts.
