As I have already 3 production runs behind me I thought why not summarize some information about them (mainly the ripping speed) on a graph. This was done partly to confirm my suspection that Audio-CDs were being ripped very slowly. This has been confirmed by the data. The information gathered during the production runs has been summarized using the 'summarize-rip.sh' script (check scripts/ in repo) and plotted using gnuplot:
As you can see the ripping speed of Audio-CDs is much less than for data CDs (more time on the vertical axis). The reason for this is unclear as of now, it may be just that the Audio-CD disks are much more worn out causing the drive to work harder with error correction.
