Asphalt has enormous amounts of unused heat that is waiting to be tapped. I have seen a few different method's for heating water but I would like to make a system that goes straight to electricity. There is the hot asphalt on top and cold soil underneath and i believe by placing a grid of two dissimilar metals in the asphalt we can create a Seebeck effect and harvest the heat. As of right now this is only a idea and will require some experimentation to see how to produce a cheap way to implement this design.
Components
1×
thin copper wire
1×
thin aluminum or steel wire
1×
A driveway and a battery to store the electricity
so I did some work on it the past few days and have a proof of concept. this is the cheapest option and its a very small amount of electricity but when its scaled up with constant heat from ashphalt or painted concrete this could be a game changer.
you could try a "geothermal" approach.. underlay tubing through which you pump water.
Similar approach to geothermal pool-heaters.
You would only be able to harvest a modest temperature differential as compared to atmospheric temp (maybe 50C).
That said, you could operate a stirling engine (better efficiency), peltier (worse efficiency), use for domestic heating or something funky (think "refrigerator that runs off of a cycling heat source" http://apptechdesign.org/technologies/solar-refrigeration/ )
so if you think about it you have the heat in the asphalt and the cold of the ground underneath. Im hoping that will be enough to produce a good amount of electricity. I will do some experiments next weekend.
Yes. A peltier solution would be surely too expensive. But a two-metal grid doesn´t cost that much. An asphalting machine could be modified to inlay metal stripes. Perhaps :-D I hope so!
yeah so we were talking about even a conductive paint that you could paint on old parking lots when they need to be resurfaced maybe applied with a robot so it makes the connections between the two kinds of paint? sooo many possibilities and things to try and develop.
yeah so that would be the experimentation to see what can be produced with different methods of doing this. and yeah that I was going to do is make a bunch of squares of asphalt.
I really like the idea. It would be awsome if you would build something like a square-foot of a street-like structure including the grid to estimate the power capability.
I'd much rather have this than "solar freaking roadways" .
