Adding a brush to the suction
12/16/2016 at 21:19 • 0 commentsMy suction works well so far but it should work even better with a brush!
Dust suction
09/02/2015 at 18:07 • 0 commentsIt´s been a while since my last log entry. I had a lot of work with different CNC projects. During this time the router had blow out a lot of dust in my workshop. Of course I have a "manual dust suction" with a vacuum cleaner but this works not good enough.
So I decided to upgrade my router with an automatic dust suction which is always available!
Electronics
03/29/2015 at 19:25 • 0 commentsY axis limit switch
Z axis limit switch down direction
Y axis limit switch
Z axis limit switch up direction
The complete electronics are housed in the backside of the portal
Assembling the Z axis
03/25/2015 at 21:05 • 0 comments -
Assembling the ball screws
03/25/2015 at 21:00 • 0 commentsY axis.
X axis
Assembling the supported rails
03/25/2015 at 20:57 • 0 comments -
Wood working
03/25/2015 at 20:49 • 0 comments -
Material
03/25/2015 at 20:43 • 0 commentsA lot of screws...
The raw material. 18 mm birch multiplex ply wood.
Supported rails. 20 x 800, 16 x 500, 12 x 200 mm
Nema 23 stepper motors, TBA6560 stepper driver, 300W power supply
Ball screws. 16 x 800, 16 x 500, 12 x 200 mm
The Kress 1050 FME-1, 1050 Watts, 5000 - 25000 rpm
The Eurohals holder.
