Hacked my barbecue, and went from there...
Propane Monitoring - Not Easy To Do!
In order to understand why I believe the ProReg will be a breakthrough in the measurement of pressurized finite fuel systems, it is important to understand the physics behind the liquid and gas mixture that resides inside of your propane tank. When holding temperature constant, the liquid and gas mixture of your tank will always return to an equilibrium pressure. To clarify, a propane tank with 30% liquid will have the same pressure as a tank with 70% liquid on a 70 degree day. Thus, taking an on the spot pressure measurement is useless. With this project, I hope to prove that it is possible to accurately predict fuel levels without a scale or a liquid float gauge inside of the tank.
Making this technology work before the IoT revolution was not commercially viable, as each propane monitoring system would require expensive hardware and software at the sight of the measurement. With the proliferation of low energy wireless connectivity, we can finally create a cost effective system that will send data readings to the cloud where a central database computes propane usage and sends that calculation back to the user. Below is an example of the data-set provided by the maiden run of the ProReg. It shows an initial reduction in gas with the burners on medium, then the slope decreases as I turned the burners up to high, then pressure starts to increase back to its equilibrium after I turned the grill off, then It begins to decrease again after I turn the grill back on, and eventually flat-lines as the tank runs out of gas.
Frank Vigilante
sparks.ron
Weishan (Wesley) Yang
Initial State
Mauro Riva
I'm not trying to discourage you, just want to point out that a tank of propane has propane in two phases, liquid and gas. As the gas phase propane is used the liquid propane undergoes an endothermic phase change from liquid to gas. This is why the tank gets cool as you use it. As the gas is used and the liquid changes phase and turns into gas the pressure will rollercoaster a little but remain relatively level until all the liquid has phase changed to gas, then you will get a pressure drop.
A way around this would be to track flow and keep a running total from when you start out with a full tank. So, 5 lbs of propane equals 5x(gas expansion for propane) equals Y liters of gas. Differential Flow can be measured with your pressure transducer across a fixed orifice.
