Introduction
For the "brains" of my smart greenhouse, I've been considering multiple options. I am currently working with the Raspberry Pi, a great platform but limited in raw performance and potential I/O expansions (note this platform will be placed indoors and communicate using a wireless link with the greenhouse). The other option I've been considering is using a Beaglebone, which is more powerful and has a lot more I/O options (multiple SPI, multiple GPIO etc.).
Another great benefit of the Beaglebone is the onboard eMMC storage, which saves you a memory card (although I currently use a 16GB card).
Challenges with the Beaglebone
Although the Beaglebone is a great platform at a great price point ($45), I have been experiencing several challenges to get the platform to work.
The Angstrom distribution is limited and not all packages are available (at least I couldn't find them). I want to use iPython as an "interactive learning environment" and I couldn't get Numpy to work on Angstrom.
I had some earlier encounters with Angstrom when working with the Beagleboard and I wasn't happy with it (needed a lot of kernel hacking to get all hardware to work properly).
Ubuntu works like a charm, but I had several issues with getting SPI to work properly. The device tree manager has been documented very poorly across the various sites and the older version I used earlier didn't work well with SPI. A newer version (14.01) does work well, but nobody describes what is the correct output.
Finally, the original tiny RTL8192cu dongles seem to work at a glance but have a lot of stability issues when plugging directly in the Beaglebone. Even using extension wires didn't solve the problem. A switch to a NetGear WNA1100 (based on an Atheros chipset) did miracles. I now have a rocksteady connection.
Figure: BeagleBone Black with WNA1100 wifi dongle.
Conclusion
So in the end I have two viable platforms to form the "hub" communicating with the greenhouse. I haven't made my mind up yet which to use. I think it all will depend on how much I want to expand on the central hub. I am thinking of adding a display and potentially some other UI elements and that could benefit greatly from the additional GPIO's from the beaglebone.
eelco.rouw
In this post, you mention that you have NETGEAR WNA1100 working with the Beaglebone. I am having great problem getting the NETGEAR WNA3100 on my beaglebone (that runs Ubuntu). Can you give me a hint on how to do it. Thank you
Nann
