Got space enough to wrap a proper coil around your finger
the drawback on NFC rings is the ammount of storage, i was able to compress a text file with xz encryption and get a custom made 256 common bit encryption key with the ammount of storage in the couple dollar nfc ring. rings feel strange to wear imo so ide get this for card.
cheap chinese on aliexpress ;-)
but if you put authorisation , for example two ring and sutup for working/open or not this will be great (for example https://img1.etsystatic.com/002/0/5943963/il_570xN.380008231_jphg.jpg )
