Steampunk Netbook
I had an old netbook. I had time. I had an idea.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is a project I completed in 2013. Stained wood with brass and copper fittings. The screen is 8.9", 1024x600 and encased in a copper stand that allows it to rotate 180 degrees. The side of the case opens via the brass clasps for easy access to the internals. Drilled brass ports at the top and bottom of the removable panel provide an airflow path over the internals. Ports are located on the top and back. The computer is fully functional, with an Intel Atom 1.6GHz processor, 1.5GB ram and a 320GB hard disk. More pictures are coming soon, since the posted pictures are of before it was finished.
Rich text editor
