Notice: this project's name has been changed from "Tyfone" to "TyTelli" to avoid confusion with Tyfone Inc.
Note that in the video TYOS 0.1.0 is used. Many, many new features have been added since then.
Hardware
The TyTelli is made up of a few basic components:
- The Raspberry Pi
- The cellular module (FONA)
- The 3.5in TFT
- 3D Printed case.
The Raspberry Pi handles all the processing, and connects everything together. The TFT talks to the Raspberry Pi over SPI, and the FONA talks to it over UART. Everything is powered with a 1200mah battery connected to the FONA. The FONA has a charging circuit perfect for use with the phone. Since the battery is only 3.7v, a boost converter is used to boost the voltage to 5v for the Raspberry Pi and TFT. A metal speaker and microphone is connected to the FONA for audio, along with an antenna. The FONA also has a real time clock built in, so the Raspberry Pi can keep time even when off wifi connection. The Raspberry Pi also has a USB Wifi Adapter connected to it giving it internet access. Right now all that it is used for is to upload camera photos to dropbox, but more features will be implemented in the future. The Raspberry Pi camera module is used for pictures and video. Below are some fritzing diagrams on how everything is connected. Read more »
Mark Dammer MM0DQM
Ricardo Sappia
Carl Winslow
diddy
I try to run TyOS on raspbian with no success. I use a HDMI Display and I modify the framebuffer.py file to displaying on fb0 (HDMI Display) and it still not work. What could be the problem?
