1. General
For experimenting with the ESP8266 I developed this little PCB. Experimenting with the previous setup on a breadboard was no pleassure. The main benefit of this PCB is a much better acces to the program-mode and the reset over one switch.
2. Circuit
The circuit is nothing special: The serial interface of the ESP-01 is connected over the CH304G bridge IC to the USB Connector. The USB is also used for Power. A 1117-3.3 voltage regultaor supplies the module an the CH304G with 3.3V. To enter the programm-Mode GPIO0 has to be pulled to ground. On the web I found som circuit (link) to reach this.
Instead of BSS123, like in the schematic, I used BSS138. They are pin compatible. BSS123 should laso work. R4, R5 and R2 can vary. I used 2K, so the leds are quite dark but good visible. R6 is just used as bridge over another trace.
3. PCB
Based on the Circuit I deleoped this PCB. It is all SMD and single sided. This made it easy for me to etch it directly at home.
4. Conclusion
This board is a very usefull toll to play with the ESP-01 module. If you need more than the two GPIOs of the ESP-01 some of the other board with the ESP8266 should be worth to look at.
5. Future Development
For this ESP-01 Board there will be no future development. Or at least this is my stand today. Other modules with the ESP8266 Chip have much more features (the ESP-01s were just laying arround here for some time). In future I will switch over to one of these other newer modules (some are allready on the way to me). There is a goog chance, that there will be a breaktoutborad similar to this for another module in future. Ideas which i could implement in future are:
- separate Power-In Jack and/or Header
- switching voltage regulator, the linear one gets quite warm
- on board lipo charger to power it off-grid
For the follow up project see #ESP8266 (ESP-07/12) Dev Board
If you find any grammar or spelling mistakes please consider, that English is not my native language.
Alex
Wim Van Gool
electronicsworkshops
Care to share on OSHPark?
Very cool design!
