Numitron adapters
A project log for Numitron Clock
MQTT-enabled Numitron clock with Arduino and ESP8266
harri-ohra-ahoHarri Ohra-aho • 09/16/2015 at 18:10•0 Comments
Soldered the numitrons to separate boards with small screw connectors. This should make connecting them a bit easier and also make replacing a tube possible in case a filament burns out.
