A simple bicycle computer that shows speed and distance on a LCD screen. It works on LiPo batteries and uses a reed switch as sensor.
Good evening guys, how you are all doing well.
I have now finished testing the code and also validating the hardware for my bicycle computer; You guys can check the final files (both Arduino firmware and PCB) on the links section of this project.
The last step on transforming this project on a real product is making a nice little case for it. I guess I am just lucky, because this week's hackaday prize giveaway is $50 on 3D-printed parts. This chance came in a nice time, since I have never played with 3D printed objects, and now I have the chance!.
I have already started designing the parts on "123D Design", using examples available in the software's main page (from Autodesk). Great news and great parts designs are to come!.
Good evening guys, how are you doing today?
This week's giveaway is about Teensy! what a lovely choice from the #Had team. these Arduino-compatible (Cortex-M0 powered) little beasts are the choice when you need low power consumption, high speed, processing capability and space reduction. Not to talk about off-the-shelf solution :) .
When I saw Myke's post I knew I needed a Teensy LC for my little bicycle computer. By adding it to my design I believe I will be able to shrink PCB real-state while keeping it modular and Arduino-compatible (all of which are part of the original idea for this project).
Good afternoon everyone,
In case you have not seen yet, I have added the link to the Github code of my bicycle computer (in the links section of this project). I have also added a link to the board schematics on the same place.
Regarding the project functionality, I have tested it on the bench (using an Arduino to simulate the spin of the bike wheel) and I'm proud to to say it works!.
Next step will be adding communications to the bike computer, so that one can connect its cellphone to it; this is where the hackaday's giveaway comes to scene: they are giving away a bunch of bluetooth LightBlue Bean BLE, which will perfectly fit my needs: these little BLE boards features (besides the obvious BLE) an ATMEGA328, the same processor I am using as the guts of the project! perfect matching :) .
So this week's wish is to get my hands on one of those LightBlue Beans.
Hi guys!
Today is a Saturday, so it means this is the making day for me!. I recently got the SMD ATMEGA328P-AU on the mail, so the task for today is assembling and testing the pcb and code.
After an hour (or so) I have finished assembling the PCB, and managed to upload the blink_without_delay sketch to the Arduino (that leaded to the yellow led to blink!). So far so good, the board circuitry is all good, next step is uploading the actual bike_computer firmware to it and start debugging.
See you guys next time,
Hello guys,
This update is just to let you know I received my custom Printed circuit boards from China: I ordered them from "SeeedStudio Fusion PCB service", a cheap and simple way to buy pcb's for hobbists.
It took 60 days to arrive in the mail, because I live in Brazil (where the government mail service is a mess..).
Now I am waiting for the SMD ATMEGA328, which is coming from ICStation (China as well). When I get it will start assembling and testing my bike computer!.
Olá tudo certo? Gostaria de saber que tipo de bateria você usou em seu projeto? Onde você conseguiu ela?
Olá Rodrigo, tudo certo sim!. Então, tô utilizando uma bateria lítio-polímero de 100mAh, que dá uma autonomia de umas 3h para o projeto. Comprei pelo eBay >> http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR2.TRC1.A0.H0.X100mah+lipo+battery.TRS0&_nkw=100mah+lipo+battery&_sacat=0
This is really amazing project of running bicycle with the help me computer. I'm working on the similar project to running it on nursing students laptop, you can read here some detail https://besticious.com/best-laptops-for-nursing-students
