Wrist cast
This is a water proof wrist cast
0 followers
This Project is a waterproof cast for yours or anyone else's broken wrist. We created a 3D printed Wrist Cast and it is pretty stable if you ask me. My friend Jose and I decided to create this Wrist Cast for people that are in need of a cast able go into the shower and be used without any breaking or itching. It may also prevent stink odor when wet or humid cause of it's solid surface. This Wrist Cast is light and easy to clip off an on. It is able to open and close using mini door hinges and a latch to hold it shut when used. This Project includes a thumb hole so you will be able to have full control of your fingers. The measurements for this projects are 170 millimeters on the wrist and 240 millimeters on halfway the arm.
jaquez spinnato wrist cast 4 final.STL
Standard Tesselated Geometry - 65.32 kB - 02/14/2018 at 20:35
Download
