FTC_Tetrix_Motor_Mount.zip
A zip file that contains a STL and a PRT file for a 3D printed motor mount.
x-zip-compressed -
784.12 kB -
02/19/2018 at 07:17
Download
FTC_Tetrix_Omniwheel.zip
A zip file that contains the pieces needed for printing an omnwheel. Contains STLs and PRT files for one roller and for half of the omniwheel frame
x-zip-compressed -
1.91 MB -
02/19/2018 at 07:17
Download
FTC_Phone_Support.zip
A zip file that contains our own phone support for our FTC robot. Includes a STL file and a PRT.
x-zip-compressed -
1.90 MB -
02/19/2018 at 06:38
Download
FTC_Relic_4Parts.zip
A zip file that contains a FTC Relic Recovery Relic, split in 4 STLs, each taking about 2 and a half hours to print.
x-zip-compressed -
4.07 MB -
02/19/2018 at 06:24
Download
Idler_T5_10mm_24T.zip
A zip file that contains 3D models from Thingiverse, that we used to guide our T5 belts in our custom-made tank drive we madel last summer.
x-zip-compressed -
67.39 kB -
02/18/2018 at 17:22
Download
odometer.zip
A zip file that contains our 3D modeled odometer support for last year's robot. Includes SCAD and STL files
x-zip-compressed -
6.46 kB -
02/18/2018 at 17:22
Download
particle_guide.zip
A zip file that contains our 3D modeled particle guide for the last year's robot. Includes SCAD and STL files
x-zip-compressed -
3.34 kB -
02/18/2018 at 17:22
Download
Usb_strain_relief.zip
A zip file that contains different versions of strain relief for our usb cables in STL format.
x-zip-compressed -
63.22 kB -
02/18/2018 at 13:07
Download
Modules_support.zip
A zip file which contains two STLs. The Modules_mount is a support for any ModernRobotics electronics modules, and the Modules_base is the base for those mounts. More information in the "Details" section of the project
x-zip-compressed -
69.08 kB -
02/18/2018 at 13:03
Download
120_gear_double_height.stl
A double thickness 120 teeth gear, used when you don't have the money to buy metal gears
Standard Tesselated Geometry -
7.77 MB -
02/18/2018 at 12:59
Download
80_gear_double_height.stl
A double thickness 80 teeth gear, used when you don't have the money to buy metal gears
4.24 MB -
02/18/2018 at 12:56
Download
Sensor_Mount_L_2_Thingiverse.STL
A reinforced L sensor mount for ModernRobotics sensors.
122.54 kB -
02/18/2018 at 12:50
Download
wire_clamp.stl
This is the wire clamp we use to organise our wires around the robot, and it fits perfectly inside the channel.
12.19 kB -
02/18/2018 at 12:48
Download
Sensor_Adapter.STL
A flat adapter for ModernRobotics sensors, useful when you want to screw the sensors on the Tetrix profile.
160.34 kB -
02/18/2018 at 12:48
Download
20x20_double_profile_end.stl
This is our 3D modeled double end cap for a doubled 20x20 aluminium profile.
simplify3d_stl -
710.73 kB -
02/19/2018 at 06:46
Download
20x20 end cap.stl
This is our 3D modeled end cap for a 20x20 aluminium profile, because in FTC you are not allowed to have sharp edges, and they are very useful when you don't want to polish every profile end on the robot
196.86 kB -
02/17/2018 at 11:07
Download
40 gear double height.zip
This is the zip archive for our double thickness 40 teeth gears. It includes the STL file, an ASM part for the double thickness gear, and the original PRT gear.
Zip Archive -
1.78 MB -
02/17/2018 at 10:59
Download
FTC_IR_seaker_sensor_mount_L.STL
This is the STL for another adaptor for ModernRobotics sensors. It is useful if you are very space constrained, but is weaker than other mounts I have posted here.
119.61 kB -
02/17/2018 at 10:18
Download
big_corner.zip
This is the zip archive for our corners. It includes the STL and a .PRT file (made in creo 4.0)
Zip Archive -
1.33 MB -
02/17/2018 at 10:09
Download
FTC_flat_IR_seeker_sensor_mount_rounded.STL
This is the STL file for the adaptor for the IR seeker. We used it for the range seeker.
167.95 kB -
02/17/2018 at 10:02
Download
