1Step 1follow the instruction for making a SD slot out of an SD adapter
2Step 2connect the sd slot to any free i/o pins on the prop chip
3Step 3download the propforth archive
4Step 4location the SDkernel.spin in the archive, and extract
5Step 5using the SPIN TOOL edit the SDKernel.spin to use your I/O pins, and load the configured file to the prop
6Step 6run the intialization script (its in the same directry as the kernel)
7Step 7change the data logger script so it takes your data (explained in the wiki pages)
8Step 8Load the 4 data logger files
9Step 9reboot
10Step 10set the clock
prof_braino
