• Fancy Brushless Motors
    zakqwy • 05/22/2015 at 04:13 • 9 comments
    Six of 'em, to be precise:
    Four different types. I'll address them one by one, starting with the smallest.
    Japan Servo Co. Type BH55FT8-02 / 8131A / AX050249B
    24V, 2A, 8W
    Only one of these motors. It's the only one that has two discrete SOICs, part numbers LB11923 7UKM (the 3-phase brushless motor driver IC) and 74HC4052A, which appears to be an analog mux/demux chip.
    As I'll touch on later, these motors don't like getting taken apart; I can't get the rotors off without getting a bit destructive. However, these vias might be leading up to a few Hall effect sensors:
    Note the beefy coil connector too--three of these spaced at ~120 degrees, as one would expect. I didn't get a shot of the underside of the board; it's got a lot of discrete components, and the white connector is labeled as follows: 24V, 24V, P.G., P.G., S.G., 5V, LD, S/S, F/R, BRK, CLK, H/L, and ENC.
    Shinano Kenshi Co. DR-6236-174 / GX060015F
    24V, 2A, 18W
    Two of these fellers. The single driver IC on one is impossible to identify; it looks like the label has been etched off or otherwise obfuscated. The other one looks like this:
    SK3002 747 T68 doesn't bring up any matches. Hell, how do you guys find datasheets online? I keep coming up with really sketchy looking sites.
    Since I had two of these (and they're smaller than the other pair) I decided to putz around with one of 'em. I used a bit of 6-32 hardware to build a little stand so the motor could rotate freely on the bench. I built up a breakout cable using one of the original connectors from the copier (thank goodness I kept the wiring harness) and fed the motor 24VDC and 5VDC; when I pulled the START/STOP pin high, the motor started twitching. It seemed to twitch once per rotation and would do this maybe 10 or so times before shutting down.
    I cobbled together an Arduino driver that allowed me to send a 5V 50% duty cycle square wave to CLK; when I did this and hit the START/STOP with a HIGH signal, the motor responded by spinning at [what looked like] maybe 500-1000 RPM or so. Sending 5VDC to the CW/CCW pin, as expected, changed the direction; I think HIGH = CW, but I could have it backwards. Either way, I didn't figure out what LD or BRK did, and I didn't test CLK above 1 kHz or so.
    I also put a bit more effort into pulling the rotor housing off one of these units, starting by removing the label:
    Looks like they assembled the motor and used a press to push a serious divot into the shaft, spreading it out and sealing the whole deal up. I don't think this was a malicious move to keep would-be hackers out; it's just a cheap and effective way to securely attach the rotor (which is presumably lined with magnets) to the shaft. Either way, I didn't want to drill it out so I tried the other side:
    Kinda a funky looking snap ring. I don't have any fancy snap ring tools so I donned safety glasses and popped it off with a screwdriver; however, nothing seemed to come apart despite some pretty serious encouragement.
    One other thing to note on these two motors:
    So it's pretty tough to see, but the two lines between the rotor housing and the circuit board appear to be some kind of component. There are a number of identical ones all around the circuit board, too. Maybe a bunch of Hall effect sensors? Man, that would be sweet.
    Japan Servo Co. Type BH60FT22-04 / 8218A / AX060310C
    24v, 2A, 22W
    Two of these guys too. Beefy, with a machined mounting bracket instead of the stamped piece on the previous pair:
    Same driver chip as the smaller Japan Servo Co. unit, but no mux/demux visible (I suppose it could be hiding under the rotor):
    Pinout:
    Nidec 58M404A010 / AX06 0311B
    24V, 3A, 40W
    This one is pretty beefy.
    Driver chip is on the back; it's a SOIC, and quite difficult to read. I couldn't get a good picture of it (well, I struggle with good pictures in general, but that's another matter...) but I did make out 62FV towards the end of the part number; any ideas? In any case, it's also got a heat sink mounted device which appears to be a bundle of FETs:
    Pinout:... Read more »
  • A few more teardown pictures
    zakqwy • 04/22/2015 at 22:34 • 0 comments
    A bit delayed, but here are the balance of the teardown shots from earlier this month.
    I found a number of cooling fans in various spots; a few of them use hilariously complicated and intricate ducts to direct air exactly where the designers needed it:
    The copier uses a number of high voltage (well, somewhat high voltage--low kilovolt range) circuits to charge drums, all provided by this board:
    The HV leads run through a molded plastic tray on their way to the drums; here, I've pulled a few of the white leads out of the tray and left others in place:
    The machine uses a pretty standard looking computer, although most of the chips are Ricoh-branded (apparently Savin = Ricoh). HDD is 40 GB:
    This little curved tube is actually an Archimedes' screw for transporting black toner. Yeah, it pretty much got everywhere... as cool as this part was, it was too messy to reuse. Another interesting note--take a look at all the blue permanent marker scribbles! Tons and tons of these all over screws, brackets, wiring harnesses, and more; I'm guessing they're part of a final quality check at the factory:
    Okay, so this is what we all came for: motors. The copier has lots of motors. I'll follow up with a thorough inventory of stuff I grabbed, but you can see a number of digital brushless motors in this picture; they're all pretty heavy, 24vdc, 16-24W, and include small helical drive gears. No datasheets, so reusing them will be a fun challenge:
  • An Excellent Saturday
    zakqwy • 04/13/2015 at 20:01 • 0 comments
    We had some spectacular weather in Minneapolis this past weekend. Definitely the right time to drink a few beers and rip apart a photocopier behind your house. I'll get into the salvaged parts later; for now, these are a few shots I grabbed while disassembling the unit (with italicized comments above each image).
    The stationary portion of the imaging system: an excellent lens, a large line sensor array, and a dedicated processing board. Not pictured: a few first-surface mirrors mounted on the moving head.
    These four sleds accept the individual toner cartridges. They've each got an integrated limit switch to detect insertion, and the cartridges themselves engage with the white gears (you can see the one for the black cartridge) that drive internal augers for toner extraction. Messy, but not as bad as I'd feared:
    Back end of the previous image, including tiny viewing windows for each toner cartridge. The bundle of white wires in the lower left corner are HV leads for charging various drums and such; the smaller circuit are (I believe) some kind of toner detector for the low toner warning system:
    I got curious and pulled one of the rubber hoses off; I assumed they were air lines for something, but I didn't expect it to be packed with toner. This has the look of a plugged pneumatic conveyance system, but I can't imagine that working reliably with rubber hoses. Any ideas?
    Ah, the pinnacle of 90s innovation: the integrated fax machine. This subsystem features 2 (!!!) backup batteries, as well as a crappy external speaker (connected via the white and red wires) for classic fax machine sounds:
    A fine day's work:
    More to come!
