I've bought one of those cheap LM386 DIY kits on eBay and upgraded Zynthia to be fully stand alone. I only had 10 red caps for the resistors, so I took green instead and a dymo label, the last switch is now the power switch :) I also mixed up one power cable and without checking I've almost killed a battery by shorting it :D
http://www.ebay.de/itm/272323639604?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
beautious!
