Raspi-Shield : The Raspberry Pi add-on board
This board will let you connect your raspberry pi with outer world and add some function to the raspberry pi.
This board is useful for that people who want more from theyr raspberry pi. the board have the following features:
- 16 PWM channels
- 16 IO pins
- 8 ADC channels
- 8 DAC channels
Plus:
- Power controller (with on-off buttons)
- RTC with alarms
- Level shifter for UART, I2C and SPI port
Everything on the board will be controlled by i2c bus, and with a little python script you can control also the power of your Pi. The power controller is a pic which switch 2 mosfets and monitorize 2 GPIO pins letting you safely switch off your Pi both from software and harware buttons. Plus you can program a power on time through the RTC alarm so you can turn on your Pi at a certain time.
I wrote some python library and bash scripts for the board. Maybe someone can review the code and improve it.
If someone is intrested in the board I'm here :)
Hope this board can help someone like it did for me!
Rich text editor
kent nyberg wrote 05/29/2020 at 13:45 point
Is this still in development?  This seems like a good basis for a motorshield for a project of mine. I would realy like to come in touch with you if its possible..
