It's time to mount everything in place.
I've cut several straps out of 1mm aluminum, each is approx. 1x2cm
Bent ones are used to hold the DVD:
4 straps are attached to the Odroid cooler,. Each one is screwed to the cooler and to the main plate using M2 screws:
Photoresistor mount- made from acrylic leftovers, 2 screws are used for each surface to prevent it from moving:
PowerCtrl board is shrinked in half :) I didn't mount the calibration led, it will be attached temporarily only. On the left side the old board for comparison:
Board is mounted right beside the fan. This will lower cable clutter- power switch (and led) are attached using original short cable, photoresistor won't have to have a long one too:
