Based on the criteria specified previously we chose:
- Microchip MCP1710 3.0V current LDO regulator
- Analog Devices ADXL362 ultralow power 3-axis accelerometer
- Invensense MPU-9250 9-axis motion tracking multi-chip module
- Winbond W25Q256FV 3V 256M-bit SPI Flash memory
- Cypress Perform FM25CL64B 64k-bit SPI Fram memory
- additionally we plan to use MS5611, MS5803 and BMP280 pressure sensors
Smaller parts include:
- 0603 smd components for optimal size vs. soldering difficulty
- 2.0 pitch 2x9 connector sockets for NRF51822 connection
- 6 pin smd socket for external SPI expansion (ex. pressure sensors)
- 21x32mm LiPo battery of around 120mAh
- Tactile smt switch
- cheap Vibration motor 3-4.5V 0.06A
