Let's start with a schematic of the power supply.
This supply is built on a piece of 5 1/4" x 6 1/4" plywood (1/4" thick). The four 350 farad capacitors are soldered together in series, then placed in the 3d printed capacitor holder.
A "three cell" D battery holder is added.
The second toggle switch and digital voltmeter are added.
The second "3 D cell battery holder" is added.
Everything is connected and wired out to a plug that can attach to the dog's body.
The 9 volt battery holder (with built in switch) and the battery/capacitor power supply are attached to the body using velcro.
Because the dog was tired of being inside, I took her out for a little air.
Actually, the ultracapacitors tend to have a low maximum voltage (2.7 volts in my case), so they need to be in series to handle the battery voltage.
Why are the capacitors in series? Shouldn't they be connected in parallel?
