3D modelled and printed replacement for worn out Freemotion Elliptical
Roller.stlSTL File for easy printingStandard Tesselated Geometry - 1.17 MB - 02/14/2018 at 02:32 |
What was the layer height and did you use the supports and fan while printing?
I did .3mm for this I believe, at 80% rectilinear fill. I did use supports for the bottom bearing hole, and did not have a fan on.
I did try 100% infill, but that took forever and the print stuck so hard to my pei glass plate, I ended up destroying the bed and chucking the print with pieces of glass still fuses to it :)
