All the files (NX and STLs) have been provided
This may fit other Ford models that use a similar spline to attach the winder.
This is a replacement window winder for a MK2 Ford Fiesta after the previous one snapped off.
fiesta_mk2_winder V3.prtSiemens NX8.5 Source Fileunigraphics - 1.14 MB - 02/14/2018 at 13:47 |
Window_Winder_Supports_Required.stlSTL that will require supports for printingStandard Tesselated Geometry - 398.81 kB - 02/14/2018 at 13:47 |
Window_Winder_No_Supports.stlSTL that requires no supportsStandard Tesselated Geometry - 393.64 kB - 02/14/2018 at 13:47 |
This image was used to trace the spline, whilst a caliper was used to scale it within the CAD package, a useful way of reverse engineering parts.
